water pumps
1931flathead
looking to buy some new water pumps for the car I just got planning on a trip this year and trying to not have any trouble with it
I get new one from speedway for 180.00
I can new stock one from vintagefordparts for 168.00
witch way is the best way to go
Although I'm new to the hobby it seems for water pumps there is nothing better than to have rebuilts by Skip, email him at skip@fordsrus.com or phone at 941 637 6698 Something rings a bell that he only goes back to '32 but check with him
Send YOUR pumps to Skip Haney to be re-built! Far better than new, Third World offshore, crap-shoot pumps. DD
941-505-9085 or skip@fordsrus.com
Skip Haney
29436 Taralane Dr
Punta Gorda FL 33982
Day: 1-941-637-6698
Night: 1-941-505-9085
Talk to Skip about it. He's very easy to work with. He may work a swap with your cores. No matter, his turn-around is smokin'-fast, and the end product is incomparable, with a lifetime guarantee, to boot! DD
When I visited Skip last year, he said he normally works on water pumps at a garage in Punta Gorda until around noon. That would most likely be the day number given above. Then he heads home for lunch. After lunch he works at his shop at home rebuilding coils. This would probably be the night number. Not sure how many days per week he works this routine.
only ones I have is on my car I still like to drive it a little I don't have any that style of cores I have older ones
Older style pumps with bushings are more reliable and will last
3 or 4 times longer then 32 to 48 pumps with bearings. G.M.
GM - could you clarify this? I'm reading it as older is better than 32 to 48? Are there pumps this style older than that?
I would have thought that the time frame 32 to 48 is older but I don't know much about this yet so I'm trying to learn.
I believe what he's trying to get across is that the older, original-type design with bushings (which Skip re-builds) will outlast the NEWER-design aftermarket REPLACEMENT pumps which will likely have bearings. DD
Which way is the best way to go
What year engine do you have and do you have the old pumps that
came on this engine?? G.M.
it is a 1953 in a run driving car I wanted to put new one on before I go on a trip this summer I was going to keep my old ones for spares
I'm going to flush it all out so it will not over heat
Dennis Carpenter has them for $125 a pair. These are new pumps manufactured by them. I have used his pumps and they worked perfect.
All 53's have bearing pumps. Why don't you just send your pumps
to Skip and have them rebuilt ?? G.M.
