just an FYI.
i have had water pumps that others have "rebuilt", 3 of those would not accept grease on the impeller side. the reason is that whom ever inserted the shaft bushing on those pumps never lined up the grease hole. beware of this if you are rebuilding your pump.
if you have a pump that will not accept grease at that fitting it is an easy fix.
remove the water pump, remove the fan blade, remove the key, slide out the shaft. next find the correct size of drill bit and drill the hole down through the bushing.
note though i have found the hole size is different at the top than it is at the bottom, i don;'t know why. i drill to the most inner smaller size hole.
ou
