No. Place a 2x6 under front of oil pan and support engine using a jack. You should be able to literally twist and pull the hose off the water pump and radiator. Don't forget about the hidden bolt inside the water pump. Use anti-seize on re install. http://www.vanpeltsales.com/FH_web/flathead_waterpump-removal.htm
