John cruzin 40
Hi i would like some info on 40 flathead's water pump Such as were to get new ones? Also are there ones with a inproved impella for better coolling or is it bs? Thanks John
From what i have read all about money they can be bought though any vender at vering prices goodluk.Hi i would like some info on 40 flathead's water pump Such as were to get new ones? Also are there ones with a inproved impella for better coolling or is it bs? Thanks John
There is no way Drake is the cheapest out there. I havent seen them beat one price from my group of other suppliers. Shop around. Ask questions. Quality wise is up for negotiation. You can also get water pumps rebuild. Buy a crap pair out there and have them rebuilt. If you want I can give you the name of a great rebuilder. Just private message me.
Bassman,
Beaten to death more than once, hasn't it? Two factors of engine cooling: Water flow through the system and air flow through the radiator. So with a '40 what is the real problem? Lack of air flow from the crank mounted fan when going slow or stopped or water flow though the block. You got to love trying to figure out 70 year technology. It's fun isn't it?
BTW Was a shroud factory installed on '39-'40 cars or '39-'41 pickups? I haven't seen one yet.
Chuck L.
The Pumps my friend and I purchased from Drake are junk. The castings are not correct and when he called them about the following problems they refused to take them back as it was over 30 days from date of purchase (five pairs of pumps):
1. pump casting mounting holes do not align with the originals in the block
2. pump casting requires grinding due to interference with camshaft cover
3. water necks on pumps are tapered and hoses blew off. originals were constant diameter with no taper. As you tighten the hose clamps the hose will push off.
This is very poor service from Bob Drake. I thought he was making an effort to improve his image.
