Gentlemen, this all makes sense. It was getting dark when I took the photo and I didn't look close enough to see that the bearing slid from the front. I recently replaced my old original fan with an aluminum fan. After replacing it, I noticed a little play (in and out) maybe 1/8 inch. I pulled the water pump and adjusted the shaft collar for no play. Something must have put pressure on the bearing to move it out of place. This is a "B" water pump as you probably noticed and I read in another thread that they are getting hard to find. Now that it's daylight, I'll have another look at the pump. Thanks for the replies.
