I IndyA Member Nov 30, 2021 #1 A Model A friend is installing a new water pump with the Thrust Collar kit behind the fan blade ...Does he need to grease the nylon washer ? Thanks for your expertise....
B Brentwood Bob Well-known member Nov 30, 2021 #2 When the front bearing is lubed that should take care of it.
