So, is it possible the collar has slipped to the front end of the shaft? BTW, the pump has no leaks, and no side to side shaft play.
The allen head screw was tight. It looked like the collar could rub and wear the back side of the pump housing at the front if it was snug enough to drag.
Should I slide it to just in front of the packing nut and pull the shaft forward to take up the endplay?
I have a four blade fan, crack free for now.
Maybe next weekend when I have more time, I'll tear into it.
Thanks.
