if your not going to reuse the hose again, that a knife of hack saw and cut the hose close to the radiator and water pump outlets, if you can get a big pair of chanel lock plyers and grip what is remaing of the hose and twist it till it freezes up, be careful with the radiator outlet, if you cant do that, take a knife with a sharp stiff blade and cut the hose length ways and use a thin bladed screww driver to slip between the house and outlets, becareful when working on radiator outlet, follow Vic advice and you shouldnt have any trouble, remove the fan if needed, if your gong to reuse the hose still try the channel locks and screw driver trick
