Update on my water pump exercise. I appreciate everyone's help, and after thinking about it, I have decided to rebuild an original style pump. As I mentioned, there's a gentleman here in town that has some parts, including pumps, that he no longer needs. I like the idea of the "leakless" pump, but I think I will get a little more satisfaction out of rebuilding one. I will probably regret going this route at some point, but...I've made worse mistakes.
I did make an attempt at getting the studs out, and they are stuck but good. Tried pb blaster, but no luck. I will leave them for now.
Some have mentioned not having to take the radiator off. That would have been nice, but I have a 4 blade fan, and I couldn't get the pump off without removing the radiator. It's just as well. Needed to replace the two bottom hoses, and I took the radiator to be boiled out, cleaned and painted. While I wasn't having any cooling problems, there was a lot of grease in the radiator.
This brings up another question. Since I've had the car, the slot for the crank handle, and the center of the crank pulley don't exactly line up. Crank pulley is about a half inch low. I'd like to address this while the radiator is off, but I am concerned about effects of trying to raise the front of the engine that much. If I move the front...other stuff will move too. I've never dealt with an engine install. Any suggestions?
