Merc,
8ba pumps are different from the earlier ones...the pulleys ,cast & pressed,
are FRAGILE. Hard to believe but the easiest way I've found to get the pulleys
off is to grab the impeller in the jaws of a lathe chuck and with the pump housing
supported spin the impeller at about 1000 rpm and using a .060 undersize carbide
drill drill the impeller shaft out relieving the press fit.
The Mercury pumps are the only ones I rebuild since they are not repopped,
at least to my knowledge. The made in India Ford pumps are, hate to say, pretty
good.
Charlie ny
