coupe1942
I have a stock water pump on my Model A pickup. I have a back up leakless water pump, but I don't want to pull the stock one off the truck at this point and simply want to repack it. In untightening the big washer, I found that there was no evidence of any graphite packing material left inside of it. To me, this implies poor maintenance from the previous owner, but none the less I need to repack the water pump to determine if it is still good or perhaps the shaft is too worn and it is in need of replacement.
I know they make different style packing for these pumps, but I opted to go with the string type instead of the split washer style. The sting type comes in a package of two and my question is, are both strings necessary to make a good seal or is only one to be used and the second one is for later? I have dug out everything I could with a pick and I simply have found virtually no packing at all at any end of the shaft housing and nut.
The pump obviously had been dripping as I see a puddle right below it on the motor.
My second question is: Is there any specific winding about the shaft that the string needs to go in as to orientation on the pump or does that actually matter in the least?
My third question is: How tight is snug or how tight is tight enough to be secure and correct. Hand tight? My big mitts have a nasty habit of not knowing just how much torque they contain.
I have watched a couple of videos on YouTube, but they really didn't help much in answering the questions I had about the string-style packing material and its application.
Thanks for any info. Working out inside my humid garage today and enjoying myself a bit while I can.
