Water pump is tough to spin. Normal?
Sparta
Hey guys! My two blade fan exploded so I had to remove my water pump to replace it. Upon removal, I noticed the pump spins but not very freely. It’s needs a bit of pressure to spin it. Front bearing looks rather new. Is this normal? Thanks!
There is a pointed washer that nests between the impeller and the water pump housing.
It could be out of position and binding. Take the waterpump apart, and rebuild it.
Should not be any binding, as you describe.
"A bit of pressure to turn it", Binding", "Turn freely" are very subjective terms. There may be nothing wrong with the pump, just the owners expectation of what it should be like. IMO, if it was working well before, it will work well now so leave it alone. As Bob C said, the gland packing would prevent it spinning "freely". I suspect there is nothing wrong with it.
