zedbyers
did a search and just came up with threads describing waterpump locations relative to year of block.
My engine (78 Series) was rebuilt two years ago, unfortunately I have no data from the build. I heard an intermittent noise the other day that sounded a bit bearing like and from the front right of the engine. Can't be sure as it only made the noise while underway. Hasn't made the noise since though.
Anyway I have been slightly concerned about coolant temps and it does look like the right side of the engine runs a bit warmer than the left.
Was curios to know if there is any easy way to distinguish between a Ford, Drake, Speedway or other pump?
Also, if a ford pump, any external telltale on bearing v. bushing?
