mhsprecher Well-known member Sep 12, 2022 #2 For the fitting next to the engine, use this: https://www.brattons.com/WATER-PUMP-GREASE/productinfo/12270/ The front bearing can use regular chassis grease.
rotorwrench Well-known member Sep 13, 2022 #3 Water pump grease has to work when wet and have a low enough melting temperature not to clog up the radiator tubes. I use Lubriplate 130-AA.
