Jim/GA
Sturgis and Eagle are right. Basic Physics.
In a closed system, a restriction will slow the supply to the water pump and it can't possibly pump too much too quick. Then the motor can overheat and cause the water in the block to boil. That will create air in the system which will force water and air out the overflow. The restriction that causes this result is usually a plugged radiator. In fact it is the only unit in the system that can plug up.
I agree. With the waterpump on the outlet of a Model A engine (compared to on the cold water inlet on a modern car) you have the pump sucking on hot water, near the boiling point. Pull too hard at the impeller (spin it at high RPM, like at 45 MPH) and you make that hot water flash to steam, especially if the radiator has any restriction.
Water that turns to steam (not air, Luke) has a 1700 times increase in volume!
Get some coolant actually boiling in the block, not at the impeller but somewhere in the block at a hot spot, and you REALLY start creating some large volumes of steam and out goes your coolant. That's when you see your engine boiling over.
So people who have reported success with grinding the impeller down or drilling holes in the blades on it are reducing the flash of hot water to steam at the impeller. I can see where that would help, if your radiator was "good enough". If it is too plugged up, even that won't help and you need a new radiator that flows better.
