JD-OHIO Member Feb 7, 2021 #1 I need to replace the water outlet petcock. What is the correct way to seal the threads when installing the new one. I am going to use the replacement that has the hex head on it to tighten.
R rocket1 Well-known member Feb 7, 2021 #2 I used pipe dope or teflon tape position in so you can easily open and close the valve.
Gene F Well-known member Feb 7, 2021 #3 I do it the same way as Rocket. I like the thumb turn design myself.
