I recently replaced my head gasket on my '28. After some thought I thought that I would put in a thermostat along with a temp gauge. I want to buy a new water outlet neck with a hole drilled and tapped for it.
If I remove the old neck, and replace it with the new style, will I screw up the head gasket as the two bolts also act as head bolts? I guess the simpler question is if you loosen a head bolt, are you going to mess things up even if you retorque?
Also, looks like the current neck is from a 30 or 31. Any problem with that other than length?
Thanks!
Thanks!
