I do it the same as Joe, except I also paint the mounting surface.
If you are using powdercoat, then DON'T paint the inside, as it will come loose and plug the tubes. I heard this shortly after I had a lower pipe powdercoated INSIDE and OUT. A couple months later I saw bits of the powdercoating laying on top of the tubes.
