Willit Stop
Last week I took my secondary ride for a drive and it was a little low on fuel so I decided to add a few gallons as I don't have much faith in the gauge. Shortly after pumping about 4 gallons of gas from the gas station it started sputtering but I was able to nurse it back to my garage. I drained and cleaned the tank, blew out the fuel lines, cleaned the pump,filter and carb and poured in 5 gallons of fresh gas (from another station). It runs fine now. The old gas has been sitting in 5 gallon covered buckets for a few days so any remaining water should be at the bottom of the buckets. By the way, I use a stabilizer faithfully. My question is, would it be advisable to reuse the old gas (less the bottom 1 inch in the buckets)? The old gas is just a tiny bit darker than new gas but doesn't smell bad. I really don't want to throw out nine gallons of gas at $5.59 per gallon. Thanks in advance for any advice.
