Mike/Franklin
Parked truck last fall with intake off. Thought I had it well waterproofed. Checked yesterday and found on draining the oil that there was almost three quarts of water. I canstill trun it over by hand. Not stuck although the reason I started to take it apart was stuck valves. Should I put some fresh oil in for now and circulated it? Any possible damage? Could inards be damaged by freezing the water in the oil pan? Motor is comming out in the next week or so to get at the innards. Oh it's an 8BA style mercury in a 39 Dump Truck.
Thanks ML
Thanks ML
