Add your general location to your profile. Northern Montana is different from Southern California.If water is better, would it be better yet with a rust inhibitor added?
I think that is the stuff I used to buy at Pep Boys.Does anyone know about using water with water soluble oil? A lot of Model A guys used to use it. It's the same water soluble oil that is used in a metal lathe that lubricates and cools the work. Anyone know the ratio of mixing the stuff?
If you read the side/specifications of "coolant/antifreeze" a 50/50 does not only help the mixture from freezing but helps from boil over, I.e. higher boiling point... I think this is well known for decades...
Yahoo answers ---- boiling point of water under a 15 psi cap ---257*F
50/50 mix antifreeze under a 15 psi cap----265*F
No answer for non pressurized cooling system----so maybe 220*F boiling point for 50/50 anti freeze? Not much help for the boiling point in our A's
