Lyle
Hello All I don,t wont to open up another can of worms. I have a 52
Ford engine. Runs very good I wonted to run it and check out the cooling situation. With a 29 model a radiator shell. Did not have a Flathead radiator.for 29 so I plugged the return in the top with a brass plate, added to return pipes on the top. Built a right side lower pan with a suction spout. Used the stock left spout. Before we go farther. I know that A,s don,t run pressure. They cant without changing the neck.I did not wont to do more soldering at this time and I do not think the A raid.would hold much pressure at all. QUESTION is do you think running with little or no pressure will work. Without over heating.I have run it with a temp. Gauge in each head and one in the top of the radiator. Run for 30 min. or more. Run RPM up and down all 3 gauges about the same 175 -178 no fan shroud.Stock fan.ambient temp. 100 here in East Texas.Speedway pumps. The old ones started leaking. A old man told me that it would work (if ) I tested the radiator by plugging the bottom pipes with tennis balls, filling with water pull the balls and count the seconds for water to drain . if more than 3 seconds
no go. I think it is going to work till I can get a new radiator ordered and delivered. What are your thoughts. I do have thermostats in it.
