I hope, someone has an idea.
After changing the regulator the motor begins to stutter when it gets warm.
The electrical system is a 12V system. The regulator was changed because the regulation of voltage didn't still work. I checked timing, distributor, checked and cleaned all gaps/contacts.
I checked the fuel mixture.
I checked sparks.
The Motor is starting perfect and runs good.
But when the motor gets warm after driving only 1 or 2 km,
the problem begins.
Checking the motor, valves work good, and I think gasket is not burned.
In my opinion the intake gets very hot. when touching the throttle at carburetor it is so hot that is near to burn the fingers.
I hope someone knows the problem.
Thank you for ideas.
I checked sparks.
the problem begins.
