Wanted / wanted
BILL WZOREK
FLORENCE
MASS.
WANTED:
More Time !!!! ;)
It seems that I am short about 2-3 Hours each & every Day :eek:
ANY LEADS WILL BE APPRECIATED :D :D
f1: I find the U.S.Postal Flatrait Box's is the cheapest way to go.
But you have to make sure it is packed tight in the Box so nothing gets out. LOL LOL
Shuttlebuggy:
PROBLEM is the NOS hours you have are not compatible with the new hours we use now. ( OLD WORK ETHIC VERSES NEW LACK OF ETHICS IN SOME CASES )
Timcharles has it, but the method he suggests is best implemented by continuous airplane flights west, so the velocity is fast enough to actually gain time (jet-lag). If you stay at it, without layovers, you should be able to build up a surplus of hours for later use.
If you believe in God we only have so much time, if you don't then you probably accept that we evolved to have only a certain amount of time here. Both numbers are reasonably close. Taking good care of your self can get you a little more but beyond that, SORRY NO MORE TIME IS AVAILABLE. I was working or Hughes Aircraft when I heard that Howard Hughes was on probably his last flight to his hospital in Florida, I paused to think that with all of his money and resources, he couldn't get any more time. Now if I can just explain the concept of available time to my 7 year old daughter.
Charlie Stephens
