Wanted Victoria Drip Rails Window Frames
dontlifttoshift
New member
Waukegan
IL
Like the Title says we need drip rails and garnish mouldings for a LeatherbackVictoria. Any leads would be appreciated.
Thanks
Donny
I take it you have a leather back victoria and need drip rails they are pretty hard to find I use tudor drip rails and make a plywood pattern of the bent in the rear heat the rail up and very carefully bend the drip rail around your pattern. on the garnish moldings which ones do you need I have some. John Hash 253 833 9364
Donny,
I have a passenger side door window frame that is decent, and a driver side door window frame that is missing the top rail and has some rust holes in the front section. I also have a passenger side door garnish molding that is in fair condition. If you are interested I can send photos.
Kirk Mohney
Gardiner, Maine
207-582-8040
