wanted tailpan 1936 1935 pieces
kustoms36
champlain
n.y
hi! bought a 36 coupe the last owner shaved thoses parts of tailpan any hambers haves thoses pieces? i know ems haves new tailpan but just d'ont want buying a new one for only thoses pieces i want replace with stock bumper brackets thanks for reply
Sorry to be a downer...you may be in for a lengthy search, as any 35 or 36 that is solid in that spot, will not likely be cut apart. I wish you the best on your search.
Behind the area you want to replace is a flat plate that is spot welded to the floor, if the outward appearance has changed the plates have been modified as well as the floor just under the tailpan. Below is the floor and the plates.
