Wanted rear axle nuts
F1 MIKE
PETALUMA
CALI
Wanted rear axle nuts = FOUND =
Wanted 1-1X4 scocket size 5X8 thread ORIG FORD ONLY will buy more than one pair. Thanks. 5/8'' - 18 thread 21/32 x 1-1/4'' special hex nut 356074-s18 GREEN BOOK I have used these before, they are HARD. THANKS AGAIN. FORD BARNERS FOR THE HELP. FOUND.
The nuts used under the perch bolts are heavy and the same thread. If I need some, I would buy the perch nuts and cut the taper off.
