i have a 47 eng that i just removed from a car that sat for yrs, it has a ford factory rebuilt tag,bored .060, it had 1 stuck piston which broke during removal and a small nick in that cyl from when i broke the piston, it is a sleeved eng, some were and some were not, the sleeve can easy be replaced or the nick may be able to be honed out , it has no cracks that i can see,your eng is 221cu. in, 3 1/16 bore, the 59 series is 239 cu.in 3 3/16 bore, it is a bolt for bolt swap with your eng, i have the block,crank, pistons and rods,cam and valves, 59ab heads, intake manifold,carb,fuel pump,starter and gen $300.00, 30 day money back guar if block is cracked, HENRY 508 451 0079, i am in MA
