Wanted: Early 1928 AR Radiator
The initial 1928 radiator is distinguished by a rectangular bracket on top of upper tank for the radiator support rods. After mid 1928, this was changed to a triangular bracket extending to the filler neck.
Also, I recently purchased a radiator and no longer in the market for one.
I still need the early bent starter push rod. Also I need an early coil with slant poles and a Ford Script.
thanks for letting me know .I looked today and do have two different radiators with the screw on cap will put note on it sorry no help on starter switch yet. I did see a coil like your describing with the slanted poles on E-bay
I looked at all my radiators and have one each like you described and they also have a sheetmetal type funnel for upper hose (rectangle and triangle brackets ) plus a third that has a triangle bracket and just a standard looking upper hose outlet.
I know you found a rad. but its nice to know what i have so they dont go to something silly(ratrod)...I cant help on pushrod or coil sorry
