I have nice tight original u-joint at $45 + postage. I have the three piece u-joint cover which is the bell shaped internal piece and the two outer cover pieces at $25.
To get action on your gas tank needs I would suggest you indicate in your ad if you need the early 30 tank that uses the instrument panel with an oval speedometer, or if you need the mid 30 to mid 31 gas tank with instrument panel for round speedometer or if you have a 1931 with indented firewall which uses a tank with outlet thru the firewall.
