Wanted 56 to 64 Overdrive Parts
mercabago55
Roebuck
SC
Wanted
1956-1964 Ford/Mercury Overdrive Parts.I need the Governor and Relay that mounts to the Firewall (12v) negative Ground,used and reasonable.I understand that some GM and Chrysler parts are the Same? Thank you.
Please E mail me at "mercabago55@bellsouth.net"
I don't have an extra relay but they do pop up on e-bay once in a while.
The governoir is not voltage sensitive as it is only a switch. They also pop on e-bay now and again.
If you can't locate a governor, I would sell you one for $25.00 + shipping.
Just curious; do you have the top loader T-86 or the HD side loader T-85 ******?
Ford
Thank you for your Response. I kinda thought the governor did not care about 6v or 12v but was not sure,As I have several Governors with no voltage marks on them.As far as the ****** ,it came out of a 1954 Mercury? T-85????? Thanks john Curtis
Since its prior to '55 and presumably a "sideloader", I would assume it is the regular old Ford ******; neither a T-86 (but better) nor a t-85 (not as heavy duty).
They are good trannys and will stand up well if not overly abused.
Hey Ford Nut
Where in Upstate ny are you? I am up there now ,staying in Frankfort for the Summer.My mercury is also up there.My name is Jack Curtis.Ph # 864-680-3715
We stock the relays...brand new 6 and 12 volt. If you have trouble locating a good used one, let me know. They sell for $139.00 plus shipping. Don't have the governors; just the solenoids, relays, and kickdown switches.
