Hi Tom, Tony from Kingston, just thinking, I have 32 rear axle bells, with axles, probably rear brake backing plates, a brand new in the box set of brake linings, the round torque tube, plus if you want, a slightly later 3:78 center section that would fit, in good shape, with the pinion still in the banjo,plus the ring gear, plus a great front axle, with a set of new Wards Riverside king bolts, complete with bushings, bearings etc. and a set of great spindles that some guys id as model A but fit the axle, plus front brake drums, the ones with the big heat releasing cut outs, plus a box of many wheel bearings. You could make me a fair offer and get it all...........just thinking!!!!! REGARDS, tONY
