Ford pick-ups (-like F100s or F150s) from the 50s thru 70s all shared the same 5 on 5½" bolt pattern as the Model-A.
The problems come from the fact that the stock Model A wheels (actually through '35) contact the drum at two different elevations. If you run steel wheels on a 28-35 brake drum you need a spacer or you risk the wheel coming off of the car. I don't believe anyone makes a spacer to solve this problem but they are simple to make. If you run '28-'35 wire wheels on the '40-'48 drums you risk cracking the rims at the lug nut holes. They make an adapter to resolve this problem. See: http://www.fordbarn.com/forum/showthread.php?p=1286293&posted=1#post1286293Wondering, with the short wheel studs......are there issues mounting steel wheels?
There is one thing you need to watch for. I posted basically the same information elsewhere on this thread but since it involves safety I wanted to repeat it.Wanted 15" steel Wheels for model A. Does anyone know what make, year, and model of car would have 15" solid steel wheels that fit a Model A hub?
The problems come from the fact that the stock Model A wheels (actually through '35) contact the drum at two different elevations. If you run steel wheels on a 28-35 brake drum you need a spacer or you risk the wheel coming off of the car. I don't believe anyone makes a spacer to solve this problem but they are simple to make. If you run '28-'35 wire wheels on the '40-'48 drums you risk cracking the rims at the lug nut holes. They make an adapter to resolve this problem. See: https://www.fordbarn.com/forum/showth...=1#post1286293
Charlie Stephens
If yours are not long enough you need to replace them. Be sure to get someone that has done it before and knows what they are doing.Thanks Charlie.
If a spacer is applied what about using longer lug bolts?
