Walt's engine pic
Walt Dupont--Me.
I haven't posted an engine lately. Here's 2-3 I've built in the last couple of month. This one is going in a model A street rod, chopped on 32 rails, T-5 trans, 50 merc with 59AB guts, .060 bore, 4in. crank, Esky max-1 cam, Esky heads, Eddy mayer high rise intake, all balanced, should make a nice street engine. Walt
Good pics Walt, it was great to have stopped up there to see that on the stand. That intake and carb set up is very nice. Scott
Hey Ray, I see your Flathead is up there waiting to get the Walt Dupont treatment. Your 37 will be that much sweeter!
The cat is out of the bag... :)
Max, those carb of your's is hard to believe. When I got ready to start that engine, I hang a gal gas tank above the engine, had a pump and filter on that engine, graverty filled the carbs, pump the carbs a couple of times, closed one choke, hit the stater button, first piston fired, opened the choke and it set right there and idle smooth like you just stopped at a street light. Your da man. Walt
