Barry in St.Paul
hi guys,
I'm running a stock generator, except with Tom's EVR, and also an Optima battery. I had noticed my horn didn't have any 'oomph" unless I was running, and then only when the EVR decided to 'charge', but thought it was just my horn ground (which WAS extremely high, and has now been corrected by scraping paint away and down to <0.2ohms).
So, expected the horn to work 'normally', but still no horn unless generator is charging. I got out the Fluke, and I have about 5.95 volts "cold", which cranks the starter just fine and the engine is running in just one or two revolutions, always. But the EVR does not kick in it seems, until the voltage is much less than 6V (didn't have the Fluke on it when it finally kicked in and started charging). When charging, I'm picking up almost 8V at the generator, and >6V at the starter/battery. While driving my little 12 mile 'loop' here, the EVR kicked in for maybe 2/3 of the drive, sometimes maxing out at 20amp, or sometimes down near 0 (but I was driving with lights on). After 12 miles and back home, I turned her off, and again, no horn. Re-checked battery voltage, and about 6.05 (hot).
I talked to Tom about it last weekend in St.Could at the swap meet, he builds these based on "standard" batteries and isn't sure if there is some odd interaction with the Optima. Anyone out there had a similar experience, and/or a fix, without getting rid of either the EVR or the Optima, both which I like?
If the horn would spin at <6V I'd probably ignore it, everything else works great. (I rebuilt horn, oiled it, and have about 0.2ohms ground resistance, and you can see the ammeter dip when horn button is pushed but "no spin" unless generator is charging...... and then it sounds GREAT!
Ideas? I don't understand the Optima's, and guessing there is something there that doesn't feedback to Tom's EVR like a standard battery does.... Thanks!
