JSeery
It seems like any change I make will take a good while to show the results in points life.
Yep, but it doesn't affect much but the rate of wear on the points.
tubman>>> Plus, there is the added complication of mounting it externally>>>
I've always considered them an extra added attraction. The only complication is they occasionally need a maintenance buff to show off their hidden beauty . 8^) Jack E/NJ
I had a Pertronix unit in the distributor at one time using this coil. The name doesn't mean anything, just the ohms. I have a few more coils on the shelf, one being an old Ford yellow top coil, and none have any more resistance. I don't understand why I'm getting such high amps using the often recommended resistance. It seems like any change I make will take a good while to show the results in points life.
Swap the Flamethrower coil for your yellow top Ford coil. Those yellow top coils are excellent coils and long lasting as well. My 1970 Ford Falcon 302 V8 still has its original yellow top fitted and never a problem. The original resistor with these was a special wire built into the wiring loom. Regards, Kevin
I don't mind swapping to the Ford coil, but the resistance measures the same. Do you have the resistance value of the wire feeding your Falcon coil?
An original Ford yellow top coil would be ok. The offshore-manufactured reproduction item is pretty much junk though.....
