zoegrant
JSeery...I am using a standard modern round coil, NAPA type, mounted on inner fender.
There is no starter solenoid as it is a foot starter type.
When you say there should be no resistor when using the modern NAPA round coil, do I disconect the red coil wire at the under dash resistor and install it to the iginition switch ?
My battery reads 6.58 volts....I do not have the ristor reading at this moment but can obtain it if needed...I am hoping that the problem of no start is due to the resistor being hooked up when it is not needed....What do you think ????
