So I have finally got my LB block assembled and installed in my 35 coupe. The resistor under the dash for the coil gets really hot, so hot the insulator base starts to stink. I believe it is functioning properly 6.3 volts in and just under 3 out. And ideas. Wiring is all new. And the voltage at the coil is near the same value.
