Fullraceflathead
Thanks for your hard work it's nice to have these available again!
Positive ground version of my 6 & 12v voltage regulators are working as of today! I'm just waiting for 1000 cutout tops to be delivered so I can finish them. These are the samples I just got:
I should have them by early March. At this point I'm completely sold out of voltage regulators with refurbished cutout tops. If you want one now, you have to send me a cutout top first. The whole "send me your core after the sale" thing didn't work out too well.....
Once I get the 1000 cutout tops delivered, I will then have all of the following products for sale:
6v neg ground voltage regulator - Model T
6v positive ground voltage regulator - model A
12v neg ground voltage regulator - Model T
12v positive ground voltage regulator - model A
Negative ground high current (30A) diode cutout (6v & 12v) - Model T
Positive ground high current (30A) diode cutout (6v & 12v) -model A
I'd like to hear more details on your regulator!
Thanks steve
What do you want to know??? Lots of background info here:
https://modeltstarters.com/voltage-regulators-cutouts/
Good info, thanks. How does it does it control field strength? Is the 3rd brush removed and it's field wire routed to the regulator? I didn't see any photos of it mounted on a generator and details of how its connected.
I rebuild model A and flathead V8 generators on the side, so I have interest in the details. It certainly is a great idea. This is an example of one I recently finished.
Thanks., Steve
It's literally a bolt-on replacement for standard Ford cutouts. No other mods necessary...
- switch the current coming from the generator on-off at a high frequency, (like PWM-controlled) and with this you can regulate the outgoing voltage. To get rid of the 'ripple' in the output current, you put in a condenser. (plus the battery, which is working as a huge condenser)
I am just curious and trying to understand things...
