Anyone use a voltage regulator in their Model A?? If so what regulator and why? I am replacing the wiring harness and the awful wiring job on my 30 Coupe. It has a lot of stuff wired to a voltage regulator n the firewall and I’m wondering if that needs to be there.
Three brush delco remy uses a 2 point regulator which functions like a cut out and the 2 brush uses the 3 point regulator. Tractors used the same set up and there are documents and videos on line that show how it connects.
I use Tom Wesenberg voltage reg, his is fool proof ,if the generator should go open circuit the voltage will remain low, not going into a self destruct high voltage runaway.
