Voltage regulator/dual master
cvicky
there's no marking on my voltage reg
is there a dual master cylinder that will bolt on 54 ford victoria drum brakes
As far as he master cylinder, I hear that people have used a 65-67 Mustang for drum/drum brakes.. I don't know if it's sized right or not. I think it only uses two of the four bolts that are on a 54 - be sure to put bolts in the two empty hole as they hold the brace inside.
What markings are you looking for?
An original may not have been marked 6 volt since there wasn't a 12 volt choice in '54.
Or, if it had a printed label on top it may have faded away.
The terminals might be marked directly on the screw lugs? Example photo...
reg standing up ,terminals on the right , my 55 (12v) is marked at top bat, middle field, bottom arm i assume they're all same (54 has no marking)
my neighbour has 66 mustang drum , i'll check it out
Your 1955 FORD has been converted to 12V ? Am I reading this correctly?
Are you describing a 1954 or 1955 FORD?
Shown is a period decorated 1956/ 12V VR -
515920
Make sure you read the pin-out correctly -
515914
... my neighbour has 66 mustang drum , i'll check it out
Paul is correct. You want the MC he described. It has to be DRUM/DRUM and you need to know if it has internal RESIDUAL PRESSURE VALVES or you have to add external valves.
Is the car manual brakes or power?
i think i've located a 65-7 mustang dual master to try
thx
your 56 reg is different then my 55 12v conversion in pics ( question answered: not all leeds are in same location)
my 54 6v with no markings, is still polarized cause i disconected battery and car kept running
thx for the help
next problem- tail lights stay on all the time until i disconected orange doted wire on switch . can i repair switch or is there something else further down the line.
... next problem- tail lights stay on all the time until i disconected orange doted wire on switch . can i repair switch or is there something else further down the line.
Tail lamps or brake lamps?
65/66 Mustangs were still single cylinder masters, you will need to look for 67/68 for dual master cylinders.
thx for the help
Your VR appears to have a decal installed. Those are available for restorations. It (VR) may be aftermarket. Don't worry about polarization as you can do this later.
515941
You are going to need a WIRING SCHEMATIC for the car for both the VR HARNESS and the lighting problem.
Which car is being discussed, a 54 or 55? Do you have shop manuals?
i'm working on canadian 54 victoria flat head original 6 v - no manual
i have manual for my 55 crown
