SoCalCoupe
I have a stock 1941 V8 (6 volt, positive ground.) When I bought the car 3 months ago, the generator was not charging. After a lot of learning and troubleshooting with help from koates I determined that the generator was functional so I replaced the voltage regulator, even though it looked like new. With that replacement, everything was fine, the battery was charging, for a short time, about 100 miles. Then on the way home from an event the generator stopped charging again.
The voltage regulator is a pretty simple piece of gear, electrical, not electronic. Why would it fail? Read a lot of old fordbarn posts and decided to just check all of the battery, voltage regulator, and generator contacts. Disconnected and wire-brushed every one on them. No charging after I started the engine and revved it a lot. Then, after about a minute of operation, the generator started charging again.
Don't trust the car yet. I'll keep a close eye on it. Don't want to be in the position of draining the battery, loosing generator functionality and having to be towed home.
Thoughts guys?
Thoughts guys?
