Let me preface this thread by slaying that I know only enough about electronics to be dangerous. I’m looking for an electrical engineer’s guidance.
I seem to have a lot of directional and headlight bulbs blow out, most recently both directional bulbs on one side at the same time. To me there seems to be an over-voltage problem, but I’m just guessing. I’m thinking that at times the generator/cut-out system puts out more voltage than the bulbs can handle.
I have three questions; (1) can a Zener diode be put into the system to limit the voltage to 6 volts? (2) if this is practical, how do I know what Zener diode and resistor to get? And (3) how do I wire it into the system?
I found a simple diagram on the internet that shows a basic Zener diode diagram that was done for 12 volts. I changed the 12 to 6 v. (see the attached picture) but have no idea if the resistor and diode would be the same.
