Problem:low voltage at coil (2.6)
Voltage at left of resistor=6.1; to right of resistor =2.9 Resistor hot within 30 sec. All measurements with engine cold, not running
Question: Should the resistor get hot? Is the voltage drop across resistor supposed to be that big? (I think not!) For the record, I get similar results with two different resistors.
Harness is new a couple of years ago.
In a post on 6/16/13 koates addressed part of the issue, but not the resistor voltage drop.
Advice and comments will be appreciated.
