I’ve got a fresh built 59a flathead with some vintage Edelbrock heads that after driving 500 miles since it’s been on the road has started to seep coolant from 4 or 5 studs total (some seep on right side, some on left side).
This just started as low temps here in NC at night dropped to near or at freezing. No seepage of coolant while driving but does a little at startup.
After the first time it happened, I let it cool down overnight and then checked all nuts with torque wrench at 35 ft lbs, then 40 but the same studs are still seeping a bit.
Should retorque to 45 ft lbs or ?
I’ve read some posts about removing coolant and use water and it will seal itself after a few runs or use some stop leak?
