I'm starting work on a 32 BB 4 cyl, it likes to blow water out of the radiator under load, no water in the oil, I'm thinking possible rad or block plugged,pulled the hoses, ran water in both,it is pretty much instant coming out the other side, of block or rad from both directions, somewhat cruddy after flushing, I've seen threads on here about vinegar in the system, I used it in the 34 gas tank and it cleaned up nicely, any reason I can't put it in and leave it for a week. I really think it could be a cracked head, head gaskets usually put water in the basement but wanted to clean things a bit before I pulled it apart.
Thanks
Aaron
Thanks
Aaron
