31chevy
Thanks to you Ford Barn people I think my heating problem is cured on my 34 pickup. a little history first, block was boiled out at machine shop, rebuilt 40 over 37 block with 34 heads intake etc. Skips pumps & coil & distributor. I took the radiator to a shop & as most of you know they no longer clean radiators, however the shop did a flow test of sorts & thought to be OK. When I first got it started it ran quite hot but I realized the engine was very tight. 1500 miles later & trying water wetter 50/50 mix etc. still ran hot. I then decided to try the dish washing detergent & vinegar treatment. I ran the detergent for a few days then drained it & put straight white vinegar & ran for about 3 weeks taking it for a ride or starting it up each day to heat up the vinegar. The crud that came out was something else! I flushed it out ran detergent in it again ran it for a while, drained it put in baking soda to neutralize it flushed out again, then straight water with rust inhibitor & water pump lube. I think now I could put it in a parade on a hot day & be OK. It running cooler than ever before. (sorry for long thread)
Gary.
Gary.
