SeaSlugs
I can give my experience on this: had about a 2 gallon bucket filld with apple cider vinegar. I threw some cast iron AA rear spring to axle clamshells in along with some regular steel grass clippers.In case one does not know it, vinegar can be bought in different strengths or the adidity strength can be increased by mixing it with a lower strength vinegar added into a higher strength vinegar. Regular white distilled vinegar is usually 5% acid, Heinz Cleaning vinegar is 6% acid, apple cider vinegar is maybe 8% acid and pickling vinegar is 10% acid. There are methods as mentioned to increase the acidity both on YouTube and on the net.
I have seen posts on Ahooga over the years in which the person claims that using apple cider vinegar on a carb restoration allowed them to sit the part up on a shelf for years with no residual rust. I can't swear that such works like that as I have not tried it myself.
after a week i pulled them out and both were clean metal no rust, about the time i rinsed the vinegar off the clippers i could watch it lightly rust. The clamshells though I pulled them all out, ashed them all off and picked the best two. Let them dry in the sun - no rust. Painted the best two and put the rest on the shelf in the garage - they are just now starting to rust again in spots and its been at least 1-2 years.
I think it all depends on the metal and cast must do something that steel doesnt....
