Model YearMake and EnginePassenger Car Model (note a)First Serial Number
(See note B below)1932V81818- 001 to 18- 203,126
1933V84018- 203,127 to 18- 457,477
1934V84018- 457,478 to 18-1,234,356
1935V84818-1,234,357 to 18-2,207,110
1936V86818-2,207,111 to 18-3,331,856
1937V8 - 60hp
V8 - 85hp74
7854- 6,602 to 54- 358,334
18-3,331,857 to 18-4,186,446
1938V8 - 60hp
V8 - 85hp82A
81A54- 358,335
18-4,186,447 to 18-4,661,000
(f)
Other: From 1932 through 1948 vehicles, Ford Motor Company stamped the serial number into the top of the driver's side frame rail in three locations.
This same number was also stamped into the top of the transmission-to-engine housing portion of the transmission. This location was visible when the
floorboard and transmission cover plate were removed (click here for a picture example). Of the frame-stamped serial numbers, only the forward-most
stamping was visible when looking down into the engine compartment (located between the front crossmember and the dash (firewall). The two other frame
locations are visible only when the body is removed from the frame. The serial numbers were metal stamped with numbers/letters approximately 1/4" in height.
The number (including the prefixes shown) was always preceded by (and followed by) a stamped "star" similar to an asterisk. It is believed that this was
done to prevent someone from fraudulently adding a digit to the beginning or ending of a serial number in order to alter its identification. From the
Ford Service Bulletins there is a bulletin dated April 15, 1938 that refers to "Engine Numbers". The subject covers the use of the correct stamps when
reconditioned cylinder assemblies are stamped by dealers. The bulletin goes on to say that the dealers should use the K.R. Wilson number A404B stamp
set. The 1940 K.R. Wilson tool catalog shows the A404B stamp set of 11 stamps (numbers 0 thru 9 plus the "star"). The same catalog shows a new
number A404 stamp set of three (just the 6 stamp, the 9 stamp, and the I stamp). The K.R. Wilson catalog states that "The design of engine numbers
has been changed to lessen the possibility of outside individuals attempting to change engine numbers. The figures I-6-9 have been changed.
Dealers should immediately provide themselves with the new figures - One-Six-Nine. See Ford Service Bulletin, Subject No. 6000 (Engine) Page 22."
