Vietnamese tires for 28-9 ford
Lucas Classic Tire….online.
Has these tires on hand. $119.
I have bought tires from them for both the Model A….
As well as our TR3. Found them to be good to deal with.
Gil. NoCal
I don't know about Vietnamese Model A tires, but I bought a set of Vietnam clinchers for my '22 Model T some years ago and after 2 years the sidewalls were so cracked that I had to replace them. Hopefully they're making better tires today.
I always had good luck with the southeast Asian tires.A tire shop owner told me it was because they came from real rubber country,with less petrolium content than other places.I always felt that they were softer,and probably wore faster.I'm sure there are helicopter and fighter pilots that can tell you of the frustration of having to avoid the Michelin rubber plantations scattered around the region.They were off limits.I have some 40 year old Insa's from South America that have no cracks,and are still soft and pliable.
Thanks for the info. I was only looking where to buy them. I have used them previously with good success. I will contact Lucas.
The Lucas tires are nylon, not polyester. Can exhibit flat spots after sitting awhile, but true out after a couple of miles.
I was looking at a set of bias ply Goodyear Polyglas F-60's for a Boss 302. Raised white letter tires like original.
At $510 APIECE I said no-way,,,, Goodrich radials are just fine:p
Don't k now where they are made but two grand plus, for a set of tires? Naaaaaw
Coker Excelsior Tires 4.5/4.75-21
$113.00
Tire, Coker Excelsior, 450/475-21, Bias-Ply, Blackwall, Each
See More Specifications | Check the Fit
In Stock (more than 16 available)
